Make sure the kick-down cable is adjusted properly, seems that as they wear they don't pull the lever back as far as they used to, almost every trans I re-build for these needs the cable tightened up to get it where it belongs afterwords. We also do it with a tranny service and most of them need to be a little tighter also. With a loose/worn setting it will let the trans shift a little earlier than it should as well as softer than it should, lots of worn tq flights shift way better after a trans service including band and cable adjustment and I always turn the line pressure screw about two turns more pressure to compensate for a little lost tension over the years. None of this makes higher than stock shift points but rather makes sure it is at least right before you go to altering things.
Agreed and good point.
