65 it's more than just pressure. You can have pressure and no flow, or very low flow. You need volume at a reasonable pressure. IMO, the lower the pressure you can use and keep the bowls full and as much air out of the fuel as you can the better off you'll be.
I'm in the process of upgrading to bottom feed needle and seats to help eliminate aeration. Every little bit helps.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
