Started fooling with them overnight,the plan was just to upgrade the locks and retainers to 10 degree but then I saw the lip that is left where the machining stopped,this picture was in process shot,at the bottom going right you can see that I knocked the lip off that is clearly visible when you look at the left side. Boy does the aluminum fly when the carbide tip touches the head,very light slow touch and it’s going quick.l
