100 LL is designed to be used in low compression motors, under 10 to 1 ratio, low RPM motors (under 3000 RPM) and it is designed to have a shelf life of 18 months the last time I check about that. It is used in turbo charged aircraft motors also but they are less than 8.5 to 1 comp. ratio to start with also The specific gravity is usually right at 690 also, pump gas is more. My message is you will need to tune your motor, jetting, timing and spark plug heat range also, to run it and you may still have parts longevity issues It is way better than your standard pump swill but I have never use the Sunoco 260 fuel your asking about so I can't give you a good reply about that, sorry
