Don't disagree on the detonation. But. Flat tops - 11.5:1 static compression, C12, run fat enough to color the plugs, 36* timing, 140-150 degrees, old (mild) roller cam, not burning oil, filled to the water pump holes, everything studded...and the caps were dancing.
If the results don't match the theory, change the theory.
