Well, you've either gotta move the radiator mounting flange closer, step the shroud flange, or fab/buy some kind of gap filler to use your existing parts. Foam or a rubber seal secured to the shroud is another alternative. The problem with a filler is that the shroud is pretty thin at top & bottom for a filler mounting surface. Whatever you use also needs to be OK against radiator heat.
