As long as the OP doesn’t have any qualms about running a higher octane fuel if required, the motor should run great with 11.5cr.
If real pump gas compatibility was the goal, Then I’d be looking to have the motor be around 10.5cr, which is really going to require a piston change.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
