The Trick Flow 240 heads will make 650 hp but your compression is going to be higher than what you want. Not a lot of 84 cc heads out there other than Edelbrock or 440Source.
Do you already have the pistons? If so then you are kind of stuck. You could get some ported Edelbrock heads but they'll cost more than out of the box Trick Flow heads.
