Did the instructions say to install the studs finger tight only, not to torque them work
If so by torqueing them your probably asking for problems like you have work shruggy The studs need to basically almost float in the heads or blocks so the all threads can touch and be tighten against the threads in the block or heads, not tighten or torqued scope
What torque are you using on the retaining nuts?
