can the TCI (super pro or master race kit i forget which it was) burn off that quick? It can if run with improper pressure. Did you not run this previously with no throttle pressure linkage attached? Complain of soft 2/3? Adjusting the intermediate band will do nothing. It is used for 2nd gear only. My bet is you've wounded the rear clutch for sure, probable more. Doug
