If the turn signal on that side is working then the socket and connections are working.
agreed, from the connector behind the drivers kick panel rearward you are good cuz they both use the same large filament in the 1157 bulbs. Seperate the TS harness & in the column half of the pull apart connector with the stalk in neutral there should be continuity between the white wire which is the power coming downstream from the brakelight switch into the TS harness/switch & out to both of the "out wires for the dr/pass brake lights. that'd be a start. EDIT
www.mymopar.com will have the colors for you but both should be hot at the same time in neutral (both brake lights light up when the turn signals ain't in operation).
