Originally Posted By Cuda340
My 70 V code Bee is an original track pack drum brake car. I have the original drum brake booster in one of my totes. I will check it out later tonight. How do you tell the difference between a drum/disc brake booster?
I believe the boosters were the same. The MCs were different. 70 B Body disk brake MC the lines exit toward the exhaust manifold.
