Re: '70 master cyl spacer?
[Re: 70mopes]
#1245847
06/07/12 02:00 PM
06/07/12 02:00 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
A bit off the beaten path....
I have a '68 charger with power drum brakes that was missing all its components when I found it. I got all the original parts but I did not use the spacer being discussed. I have had some strange issues with my brakes since building it and have got them to work pretty good but not perfect.
Question what would be side affect(s) of a power drum brake car that did not have said spacer installed?
I have never seen this part before so if I were to try and find one or fabricate one, how should I go about it?
Thanks!
PM member Chargervic; he just took off the drum brake booster with the spacer off his '68 charger as he's doing a disc swap. Without the spacer, I'd imagine you may not have enough adjustment in the rod pushing the master cyl piston in which could cause travel issues, difficuly bleeding, etc.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
