What weight oil was used in it and how much pressure is "low" ?
I like and use the old rule of 10 lbs. per 1000 RPM with hot oil, in other words 20 lbs. at 1000 RPM is good as long as it has 65 Lbs. at 6500 RPM
I like and use 5W20Wt oil in all my street toys now
My old 518 C.I. pump gas wedge stroker motor had 70 lbs. cold at 1200 RPM with 5W20Wt. oil, it had 18 to 20 Lbs. idling at 800 RPM with the oil temps north of 170 F and it had 65 Lbs. max above 3000 RPM with hot oil.
I had to trim the high volume bypass spring 1 1/2 coil to get if down that low after running the motor, stock it would have 80 lbs. cold idling and make the bypass spring work above 3000 RPM (it would bypass at 80 Lbs> no matter what the oil temps. where
