It is fairly common with inexpensive aftermarket parts for the marks to not line up. Typically if you use the higher dollar stuff like an ATI damper and a high quality stroker kit the marks will align.
It isn't a serious problem but you need to sort it out. A piston stop and some timing tape is a good way to figure it out. If your damper is fully degreed then you don't need the timing tape.
