Update, did the air check and got hissing noise in the rear clutch. Got trans out and apart. Rear disc-steels burnt and warped bad. Setting on the front pump housing after replacing with new steels-disc, applied air pressure, piston moved but small bubbles around inner seal so I replaced. Seems to be working ok now.. I'll go thru the VB tomorrow, might have got something wrong in it.?
Anything else I need to check?
