Replaced an A/T with a new Temec. All is good but there is an annoyance. Wired in the neutral safety switch but that things does its clicking thing every time the shifter passes through neutral when being shifted. I could jump it out perhaps but I am hoping for options. I’d rather have the switch operational but I am not going to be able to tolerate the constant clicking under the dash. Ideas? BTW this is in a ‘72 Charger.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
