If one were to build a stock 426 or even a stroked 472 Hemi for the Street using a cast iron block and Mopar Performance aluminum heads, is there any preference to using the cast iron original stands vs. using aftermarket aluminum rocker stands on the aluminum heads?
The reason I ask, I have a couple sets of both and wanted to sell a set. Not sure which to let go. Thanks.
