Here is a radial mount caliper bracket. This one is from Baer for their race caliper. They use the same bracket for all of the rotor sizes and just use a spacer to adjust the caliper height. So you can have a 13 inch, 14 inch or 15 inch rotor all with the same bracket. Just use a 1/2 inch or 1 inch spacer to adjust the caliper height.
