What’s the availability on the Viper rotor?:
-Used only?
-Can you buy new or used without a core? Typical Price?
-what is typical rim diameter needed?
That is a Baer rotor. The Viper calipers are available new from any Dodge dealer. I just bought a set of them for my car. They were $481 each at my local dealer. Not sure how much longer they'll be available but no problem buying them at the moment.
Thanks. I meant to write caliper, my bad.
I prefer the Dr Diff forged aluminum hubs. And they fit large bearing spindles (Willwood doesn’t have a kit for that).
I perfer the idea of a production caliper.
I’m going to run ET minilite rims. They said the Brembo calipers tend to have tighter clearance between caliper and backside of wheel/spokes.. What is the postive or negative distance between the top of the hat to the top of caliper in this new kit?
