So I finally got around to messing with the install of the new firecore dizzy and timing this past weekend. I ended up using ported vacuum, on the fast ez efi. My initial was 18 degrees and then it pulls another 5 degrees when you hook the vacuum line up. Still playing with it though to see what it is going to like best. Making small changes and then test driving for now. Thanks again for all the replies.
