So lets all get on the same page: his TRANSMISSION, not his engine.
Thanks!
I count 2 people mention the ENGINE MAIN bearing. And a couple more, plus me, mention the TRANSMISSION MAIN/MAIN SHAFT BEARINGS BEARING/S.
Dude, how far down this rat hole are you going to dig yourself into?
Transmission MAIN Bearing, which school did you learn that term from
Front input shaft bearing, rear output shaft bearing, cluster shaft needle bearings and some bushing in a lot of different stick shift transmissions, no automotive standard transmission I have ever heard of or read about mentions a transmission MAIN bearing in them
Do we really need to go on about your concerns on words used in this discussion
