After getting signed up for Drag Week 2018 I headed to the track.
It was a busy day and I only got two passes in but it ran a new best right off.
60 1.495 previously a 1.516
660 6.77 from 6.87
1/8th MPH 100.4 from 99.8
1/4 10.71 from 10.833
No improvement in MPH.
The air wasn't quite as good as some of the previous best and it is out of gear. Its best MPH was set with some bias ply slicks and it hasn't touched that since I went to a radial. I broke my 3.91 gears so I have been running some 4.56s and it is crossing at 7300 and it is pretty much tapped at that point. I have a Dana with 4.10s in progress.
I have to give some props to Mickey Thompson. I got there late in the day and the track didn't look good and there was lots of street tires on it. The Pro Bracket radials dead hooked on both passes.
