Mines at 160 would like to see it up around 200...whats your opinions..thanks rook
What's the application/purpose of the motor?
this is in my drag car..a 2700 lb 68 charger..i use race gas...and this question is not a hoax...lol
Ok,
got you.. For pump gas 175 would be about the max, but since you use race gas, well over 200 if your octane is high enough.
The BIIIG problem with your car is that your cam is WAAAY to big for your comp. People have been saying that All along but you didn't seem to be listening, hence my hoax statement.
Change your cam to around a 260-265 max on a 108 LSA max and you will get your higher cranking comp and performance. Id also install it around 102/104 ICL as well. Id personally wouldn't go any higher the the 260 @ .050 Do that and I think you will be happy.
No hoax here either.
