The floor pans were much better then I expected too. The driver's side was as solid as can be. The passenger's side had lots of little holes. A previous owner had cut a hole in the hump for a 4 speed (hung manual pedals too). That wouldn't have been bad to do but the biggest issue was that the Charger had been moved around many times with a forklift. it was forked from the side and the ends of the forks pushed the floor pans up. You can sort of see what I'm talking about from these pictures:
