It has taken me a long time but I think I'm finally ready to tack the spring perches to the axle tubes. When I got the car the rear end was bolted in place but the perches were loose. I had to get the car put together far enough that I knew where the engine was located and what the angle was so I could get the rearend in the correct location.
I had the engine mounted up a couple of months ago but then the headers arrived and they didn't fit so everything had to be moved around. If I was a chassis builder I'd go broke since I move so slow on this stuff. I suppose some of it is just experience and tools. I have to stop and build jigs or fixtures when ever I try to do something so that slows me down a bunch. Anyway, looks like I'm ready to nail down the engine position and the rear end position now. The 10 ft length of roll bar tubing thru the main bearings really helped me visualize how it fits together.
