The yellow wire on the starter relay does not have power when trying to crank the engine.
We replaced the burnt fusible link with one that has a replaceable fuse.
The wipers, turn signals now work.
Took bulk head connector apart and it looks excellent, almost like new.
Tried jiggling shifter while cranking and got nothing.
Replaced starter switch on top of column, nothing.
With key in the run position and jumping the starter with a a screw driver the engine will turn over.
