The interior lights, headlights, dash lights, flashers and blower motor do work. When you put the key in the ignition it chimes.
The turn signals now do not work. It died last night when he turned on the turn signal. When you try to start it, its as if it does not even have a battery in it. Wipers do not work now. They are on the turn signal stalk.
We have not performed an under hood diagnostic yet.
