Originally Posted By scratchnfotraction
you can use some purple cleaner and scrub brush then rinse with water save the brake clean to remove the oil film when done.
Thanks. I have been using some Simple Green too, along with a paint scraper, it's just hard to get on top and in the little nooks and crannies. I think bottom line is I'm going to have to pressure clean the layers of neglect away.
Facts are stubborn things.
