I need a little help in building my 65 Plymouth bracket car. The car is being built to perform in the 10.0 range using Caltracs and mono leafs. I am beginning to turn my attention to the front end now. What are some of the issues I will be facing when setting the front end up for racing? I understand the early B body parts are different then the later years. Do I stick with the stock geometry or update to the later one? What about oil pan and fitment issues? Should I use stock alignment specs? I will be using an engine plate so I might be able to move it back some. Any advice or recommendations would be welcome.
