hello Guys ! i have some question on oil pressure ...
oil pressure is :
cold engine idle 1350 rpm 65 psi rev over 3000 85 psi
warm engine idle 1350 rpm 25 psi rev over 3000 55 psi
in my old 496 was at 75-80 psi also at warm engine at wot
Remember ... i have _Milodon billet oil pump with external single line and GRP aluminium rod with rod clearance .0019"
i have restrictor of .040 on heads with TD rockers , the gauge pointer at warm engine at wot make a vibration at 55 psi
oil weight is Valvoline 10w60 Racing
