Hi Dwayne, I did buy the cam for this project from you (you spec'd it for the TF 270 heads). I was maybe going to give you a call sometime this week for your advice.
I know I will need new springs so I figured about $500 for the springs and machine shop install. These heads have recently been to my machinist for valve work so I'm pretty sure they are good to go except for springs.
I'm planning to use the Hughes offset rockers (part of the deal) and the $900 TTI headers setup for the Victor heads. All this figured in I'm still saving about $1500.
I'm not sure which version of the head they are. I'll need to look into that. I'm not to excited about the low/mid-lift flow especially on the street. I'd like to save some money but if the difference is significant I will stick with the TF 270s.
Thanks,
Steve
