Now that you have spent all this time on a cheap compression test, all it will tell you is you have a problem. Buy a leak down gauge and it will tell you what the problem is.
My thinking was that the point of doing a compression test was to see if you have an issue and needed to do further testing and diagnostics to narrow down the issue.
