Your test results don't mean anything. Your procedure was incorrect. Nobody seems to have noticed that.
The correct procedure for a compression test is remove all spark plugs, block throttle wide open, then do compression test. The engine has to spin over at least three times to get a good reading.
Sorry I'm sounding so cranky. My wife didn't even make me a turkey sandwich yesterday.
