Originally Posted By sp392
Originally Posted By cudadoug
Originally Posted By Spaceman Spiff
Originally Posted By Lost in life
That's a bargain to run 9's. Wish it were that cheap to make my dart run that quick! Add a zero and you would be more realistic.
You're not counting the cost of the Car.....
So, $50K+ to run 9's isn't a bargain.....
As well said earlier, this offering isn't for everyone...nothing usually is! But for the guy who already has the car it's a pretty good deal of for that power level, along with reliability. Raise your had if you've ever grenaded a high compression, roller cammed 700+ HP motor?
The big question in my mind is can you bolt it up to a 727, or do you need a $5000 transmission??
Someone do the math...
Iron aftermarket block
350 cfm heads and valvetrain
Stroker assembly
Turbo or blower to run low compression and "pump gas"
EFI
Etc...
Will you surpass the $15K mark? I'm thinking so.
They're also only a pulley, tune and injectors away from near 1000HP
Well, then there is that...
