Originally Posted By Thumperdart
In some cases the bigger ifrs/idle bleed combos help as you found out and lately I've been putting in bigger ifr's to help out the idle/transition circuits and to come up on the boosters happier instead of a big lean dip. However, this apply's to some and others may need to be leaner for various reasons but the wide band and plug reading go a long way here and a chassis dyno better yet........ beer
When you add bigger ifrs, what does it do to the idle fuel screws; do you normally have to turn them in some more?
