Turn the collector over on the passenger side and re place the tabs on the tubes to the outside. Turning the collecter over, will place the triangle of the collector to the bottom, away from the frame. On the driver side, raise it about 3/4 inch. This will also lower the passenger side away from the frame. A lot better than beating the crap out of the headers.
