Get the whole cal-trac set-up including the split mono leaf springs for the weight of the car! Once you do that it will dead hook if set up correctly. On the street they may be a little noisy as the suspension moves up and down. Its a completely bolt in deal and having a good shock makes all the difference on tune-ability
