I'm doing a 25.3 build. The only steel body parts are the quarters, tail light panel, rocker sills and roof. I have 225lb springs in the front struts. With the comlete steel block 500, flywheel, scattershield, trans, driveshaft, rear end, and steering in place, and me standing on the front crossmember, the front springs still don't even start to compress.
