Obviously, the lesser you pay for a CCW crank, the more worth it it becomes. Ohio crank sells a billet 4.5 for $1650. I would assume that has center counterweights. Or you could look for a good used alcohol crank. I scored a used moldex billet stroker with center counter weights, checked straight and crack free, for just over a grand. That was worth it in my opinion.
