That Hughes cam will be just right for that engine. What is the LSA of that cam? I looked on there web site, but couldn't find that grind. Probably a 108 cam. Install it at 103 ICL or so, which will help keep some compression in the cylinder. You got to be careful running larger cams with low compression, its easy to do.
[color:"red"]65 Hemi Belvedere coming soon [/color]
[color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
