Well after you did then it's supposed to be E coated. That's supposed to fill all void etc. pricey to dip and E coat. Think I will blast either dry or wet. Will check out all my options. don't mind using a chemical strip for the panels. learning more as I read the pros and cons
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
