Originally Posted By sgcuda
... With the new pushrod at zero, the lift is only .005" off.
With checking springs or the actual springs to be used? I check w/ both to see how much deflection can be measured in the valve train components combination. It can be a significant difference... and a bit of an "eye opener", too.
