I see from your other thread you have Jesels.
You have the adjusters out too far, which lowers the ratio.
There should be a number code on the rocker which tells what they are(offset, ratio, etc.)
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
