Originally Posted By Neil
Not 100% familiar with how those are attached. Is there a spot weld or plug weld that broke loose? Can you tell how were they attached to begin with?
Tony's Parts has a kit and from the picture it appears there are holes in the side of the plates. Maybe they bolt in somehow?
http://tonysparts.com/newproductsB.htm
They are originally spot welded from the inside of the track. What remains is a pair of holes about the diameter of. #10 screw.
I’m listening.
