Quote: Using a speed pro high volume and matched the pump opening to the block passage. My biggest problem is lowering the pressure as I have too much.
What viscosity oil are you running? I had the same problem with my Demon's 440 and ended up taking out the 20/50 and throwing 10/30 in it, it would then idle at 45 psi.
