Originally Posted By Sammy
Trying to figure out if too tight would cause the engine to stop pulling right around the 1200 foot mark through the traps. Same thing every pass but pulls fine through all the first and second gear but feels like I'm out of throttle pedal. And yes .050 not .50.
No that isn't the trigger wheel. You have a different problem, maybe running out of fuel or some other issue.
