Only issue with a tight gap is that the parts might run into each other if the crank flexes a bit. Look at your wheel to see if it is digging into the sensor. If the parts aren't running into each other then leave tight. And your numbers are wrong, you are missing a zero. MSD wants the gap clearance to be 0.050 not 1/2 inch.
