The bolt holes are in the same location just angled differently. You can swedge out the holes to the angle you need. You may need to make angled bushings to locate and support the bolts. no biggie. People do this currently to fit an LA intake on Magnum style heads. That intake will work better on 318 heads- it was originally designed for a hot 273 then 318 application.
