Originally Posted By xjsc16x
Originally Posted By poorboy
Then you also have to consider the cost of converting the magnum motor to carbs and standard ignition systems.
Replying again...like I said converting a '76 truck to EFI is way too expensive and time consuming. And way more money than converting a 5.9 mag to carbed. I already have the carb and I can get an HEI setup for next to nothing.
I converted my jeep to 5.2 magnum efi using a 94 ram engine harness and ECU. The cost was next to nothing using junkyard parts. In your case it wouldn't make sense anyway with you having the big block in there already.
